Is there an easy way to add one?
Does anyone know what the fuel pressure at the rail should be? Friend of mine said he thought 30lbs. So in this case I'm thinking fuel pressure regulator since I'm getting 60lbs at the shrader valve which according to my engine book should be what the fuel pump sends?
Rail pressure at start up is 50-60 but the regulator doesn't do anything until the engine starts.
Fuel pump charges the line, then shuts off.
Once Started Fuel pump kicks on, and then Regulator Regulates.
If you charge the fuel line and then let the fuel out of the line with the valve, the pressure does not return...Until you cycle the key on and off again
If you have the engine running and press the valve the fuel pressure does not drop, because the regulator allows more fuel through it.
I wouldn't want a check engine light. That whole set up is just another pain in my book
