It seems like anyone who has to back up an incline runs into this issue. My dealer looked at me funny when I said the reverse solenoid wasn't working right - he said none of them do. Told me to put in the little metal lockout disc and problem's solved... BUT the problem is when you stop going down a hill, need to back up, and the brakes are already engaged... disc doesn't fit and requires quite the gyrations with chocks (feel like I'm doing several chinese fire drills) to get things going.
I had some wire and went through connecting each prong on the vehicle to the running lights to see which one was which. I've got the 7 flat on the vehicle, and then a 7-5 adapter to connect to the trailer lights. Also found this diagram.
http://www.etrailer.com/Merchant2/gr...043_tt_500.jpg
Neither the brake or reverse light prongs are powered when I'm in reverse. It doesn't help that when I ask other people about the issue - they think I'm talking about electric trailer brakes and go into a whole spiel about them.... It sounds like basically you just want the "purple" backup lights wire on the vehicle to connect to the blue trailer brake wire?? So when I'm in reverse, the blue wire on the trailer is powered. Is this right? OR should the blue wire on the vehicle control this?
