So the pumps will be getting power from the switches that are getting power from the stock power panel under the dash?
If the above is true you may run into an issue that I had. When I hit all of the empty switches at the same time or engaged a fill pump and one empty pump it would pull too much power away from the dash and perfect pass started turning on and off. I ended up running a dedicated power and ground just for the ballast sytem.
