Insane work dusty on an insane ride ...:cool:
Incredible install. Gotta keep up your rep. Had a feeling you'd keep that flag holder.
Welp, went ahead and added the lighting inside the speakers. Not a huge increase in light but a nice little touch I thought.
http://uploads.tapatalk-cdn.com/2016...0e62393151.jpg
What did you use on those?
Used these, http://www.ebay.com/itm/252237414038...%3AMEBIDX%3AIT
On the 24 I used individual LED's, these were way less time consuming. Ended up cutting about 3 or 4" off of each strip, but other than that it's a simple stick em around the tweeter, use a bit of glue in addition to the double sided tape, glue the tiny power wire down the backside of the grill to get it to the edge and around speaker, wire in and done. I used spade connectors and heat shrinked them so the grills can still be removed without having to cut anything.
are the mounted to the grill or speaker? Looks great.
They are mounted to the speaker grill, around the tweeter.
Dusty, very, very nice install, your setting the bar with this one
Thanks sir!
Sent from my SAMSUNG-SM-G920A using Tapatalk
