I was hoping to use the stock pump that feeds the center bag to do all of this. Will that pump be sufficient?
What bag have you been able to fit under the bow seats? I'm in Canada, looking at a Fly High 725lbs or the X2 690lbs. Both show th same dimensions and are both made by Fly High.
I just stuck this one in mine.
https://www.wakemakers.com/fatsac-65...ump-combo.html
It fits really well but does have a little room on the legs if you went a bit bigger.
I want to plumb the IBS into the centre bag and use overboard pumps for the rear bags, looks like I might end up with two pumps soon.
For plumbing the center and IBS into the same system, if I T off the the front of the centre bag into the front of the IBS to fill and put two returns on the IBS legs to T off into the drain of the center bag, how do I vent them? I'm not even sure if the center bag is vented, that is how little time I've had with the boat since I've owned it. Thanks again to anyone willing to answer these questions.
Attachment 25697
Would this work to add on top of my center bag to pump water to the IBS?
Bump bump bump
