Perfect and thanks. We will be buying one soon!
I’ve had a couple people ask me about the seat hinges as apparently Great Lakes doesn’t carry them anymore. Here is the item #/description:
“Lund Boat Complex Piano Hinge - 2008307 - 17 1/2” x 6 1/2” aluminum”
Looks like eBay had a listing a one point but sold out currently. The important thing is that it make a “Z” shape when folded shut.
I really wished they would have added a section of fiberglass under the long cushions. Then we could have the standard side triangular hinges everyone else uses these days. Such a shortsighted design in that regard but I bet the next major Max version will have adjustments made to incorporate more fiberglass bracing and hinges can be added. While they’re at it they should redesign the bow so that A) cup holders can exist on the side with redesigned upholstery B) cushions can be redesigned so that hinges can be add. I hate how heavy the front cushions are and the shape/design of them allows them to easily drop....err... fall into the storage compartment.
I finally added some sound dampening to the floor pan/bottom of the boat. I honestly can't tell if this made any further difference or not..https://uploads.tapatalk-cdn.com/202...c617040870.jpg
Thanks for sharing HFarr. I was wondering about doing the floor. Seems like the trans cover is the most impactful. Wondering about behind seat and sides? I see that members are doing this but Has anybody seen/ heard a significant difference with these? What about the underside of the tray? My fear on this one would be that if it came unglued, it would be right above the engine.
Update on my ‘21 Craz - the dealer recorded the whining sound and sent it to Moomba. Apparently, there are a number of complaints about the noise from the v-drives and they are having to replace them. Of course, they are on back order so just have to live with it for now. Dealer told me they see a large range of whining from extreme to almost silent. Depends on tolerances.
Wow! That's pretty interesting about them replacing drives due to the noise. But good for them if the will! That impresses me. I will mention that to my dealer when I take it in for service. On the sound dampening: When I took the floor up, the first thing I noticed is how the gas tank would seem to block most of the sound getting that far up. But, I had it up so I put on the mat anyway. I have thought about the back of the engine bay, but I think the trans cover had the most impact on sound. There is a thick foam seat back there already. When the ballast bags are full, I would think they block the sides pretty well.
Do you happen to remember what size socket or Allen head I need to remove the pedestal bolts? My boat is in storage but I wanted to head down this weekend to install the new pedestal.
On my Helix it was #3 philips pan head screws.
Thanks. I guess I’ll just take a lm assortment of tools just in case mine is different.
How do I remove this plastic sleeve off the stock pedestal? I need to reuse it on the new adjustable pedestal. I am at the storage unit without a rubber mallet. Any ideas while I’m here?
https://i.imgur.com/Tu8DNNK.jpg
