Originally Posted by
goose
Hey Guys. I will try and clarify the confusion on the "sub-floor" ballast. You are correct that the rear ballast is similar to the Max. It is a rear bag with a storage bin over it. In the Makai, the storage bin is screwed down AND has a pie plate so you can access the vent if needed. In the rear, there really isn't a floor as the bags are basically on the hull, so the rear ballast being called "subfloor" or "concealed" is really a matter of preference. BUT, in the Makai, there are additional "mid ship" bags that are truly "sub-floor" that are covered by a "fake floor". Each bag holds 400lbs on each side of the cabin and that is what we really meant as "sub-floor". Also, the entire front ballast is below the floor level so it is also "sub-floor". On the Max, you could add mid ship bags, but we don't have a fake floor that is designed to cover it, but if you got creative, I am sure you could also make a "fake floor" for it. In case you didn't know, we made a running change mid 2018 and the current Max rear bags have fittings in case you want to add your own "mid ship" ballast.
Hope that clears up the difference on the Makai ballast and how it differs from the Max.
As to the dash, the Mondo, Craz, Mojo, and Makai all receive the new 7" touch screen dash as standard. It does have a new interface and I think as you guys use it, you will really love the changes. And for those interested, on the 7" screen when you have AutoWake on, you can go to the home screen and still see ballast levels as AutoWake is working. I know several had requested that in the past.
For 2019, we also have AutoWake 3 that adds Multisensor technology. Basically we added our patented "draft sensor" technology to add ballast sensor that sense how much water is really in the bag. Once the sensor sees the bags are full, it automatically turns off the ballast pumps and resets the gauges to full. This prevents the boat from "over filling" the bag which can eventually lead to walls popping in, fittings popping off, or other ballast related issues.
The Helix and Max continue to use the 480 color screen that all the other models used in 2018. The great news there is the 2019 software WILL work backwards compatible on the 2018 and 2017 models. It also has the ballast sensor technology in it. The 480 does NOT have the same user interface as the 7 inch screen, but we are trying to keep the technology moving forward so if you want, you can eventually purchase ballast sensors and update software and get a 2018 model to have the AutoWake 3 technology.
If you have additional questions, let us know. We will try to update you as we can but we are a little busy trying to make all the new 2019 models...
