Yup I’ll be cutting mine as well. I had posted that pic once I noticed the new ones came that way and knew I had to do the mod in the off season. Does it slide out eas now?
I figure the squeeze is inevitable but I’ll take that any day over what you normally have to do if you don’t remove the struts.
Why would you want to remove for resale? Who wouldn't want a quieter boat?
I've put the same stuff on my Mojo. Planning on doing the floor panel this winter if I get to it. You definitely do NOT want to fool with trying to take it off after it is applied. To answer the question, it has it's own adhesive backing and the tape is just for the seams.
^ bingo!
In hindsight I would use this for the bottom of the engine tray and sides of the engine walls:
Design Engineering 050130 Boom Mat Under-Hood Thermal Acoustic Lining, 32" x 54" x .75" (12 sq. feet) https://www.amazon.com/dp/B0055VTOBA..._uT8QFb38956GB
Hi, do you have any pictures of the plug light lit up at night? Would you go with it again? Just bought a 2018 Max and am thinking of going with ty e same light setup.
