I hate to admit it but I'm having real problems pulling into my slip. Does anyone have any tips. I'm off tomorrow so i'm gonna head to the lake and practice.
I have problems too.
I enter the channel where my lift is on the port side. When I try to turn left directly into the slip, more times then not I need to abort and back out. I have better luck, passing the slip closely on the port side, then turning to the right and turning 270 degrees and entering the slip at a slight angle toward the 11 o'clock position and slowing and spinning into the slip.
I know some have good luck approaching directly toward the 2 o'clock position and slowing and allowing the reversing prop rotation to pull the stern to the starboard as you enter the slip. i have trouble getting that to work for me.
What problems ate you having.
Comparing it to trailering the boat what are your differences?
Do you have guide poles on the dock?
I have guide poles with heavy duty ballast hoses covering to protect the boat.
I'm off tomorrow give me a call if you want to talk.
503-989-9921
Thanks Mike. I'm not sure I understand the 2 o'clock method. I'm trying to do it like pulling on the trailer, but I've only had to trailer 5 times, so I'm not very good at that either. Yes I have guide poles covered in PVC.
I'll give you a call tomorrow, AM or PM?
The 2 o clock Pat mentioned is aiming the boat at 2 o'clock then reverse pills the rear end around.
The best advise I can give you is slow slow. I always have Claudia up front to help guide.
I try to come in really straight but I have a straight shot.
Afternoon would be best
Mike - Could you possibly use your cell phone to capture video of you pulling in to the slip and post it here for Gil? - Stuart
Gil,
This is my preferred method:
https://youtu.be/9qHdPhkSSNQ
Took a short Video of putting the boat in the lift yesterday.
Don't mind the messy dock that in the video LOL.
We had a nasty storm blow in Saturday night as we were trying to come into the cove, by the time I was actually able to get the boat on the dock I was behind my dock, not on the side as normal, so I had to pull all the buoy balls, ropes and everything to the back, and in this video I hadn't got things back in order LOL.
https://vimeo.com/218474623
If you listen you can hear the forward reverse I use to slow the boat to a craw, and drive it into the dock / lift.
Also I think you can hear my serpentine belt whistling a bit, after the boat sat all night in the rain it started squeaking, I have a new one though.
I am looking at purchasing the HarborHoist from HydroHoist Boat Lifts what are yalls thoughts on them? Does anybody own one? I have seen a lot of good reviews for them but wanted to get everyones opinion on them.
That's who makes the pumping system on mine.
No complaints
I wear this badge with honor. Sent the wife into to Kroger this morning as she's walking back to the boat a lady ask me if I was going fishing. I replied no just going to play in the water. She turned and passed my wife which hears it all and the lady says asshole. Idk but I think I win right. Lol
That's a big W.
