As you increase the angle of the gate in relationship to the side of the boat it will tend to lift the non surf side of the boat making it list.
A nice side effect .
So ineffect the flow should list the boat without any weight, just the flow deployed
Not in my experience with gates which would have more potential of increasing the angle of attach to the water (like a foil) compared to a flow system. I have a couple degrees on mine to keep from water being scooped up. I can't tell. I've ran my gates without weight and there was no noted list.
Russ, two more ghetto gate questions.
What's the best way to measure the curve of the transom and do you think the pressure from the gate will crush the normal platform, non surf, with the gate?
This post Kept my busy all weekend , did a little experimenting as swell. The wake was the best I have ever got out of the LSV . http://img.tapatalk.com/d/14/09/02/uqy3u6ag.jpg
Papou
Nice work. Now that's a ghetto gate....
In this pick 750 right 3/4 full 400 right 400 centre two adults .
http://img.tapatalk.com/d/14/09/02/uzuhe9eh.jpg
Great looking wave
How did you attach it? I don't see any eye hooks?
More pictures of the gate would be nice...
ok Russ, maybe last question. how this is the gate 1/2 3/4 1" ?
would half in work you think or go to one inch.
thanks......
My guess is 1/2 will work just fine, but just a guess for me.
I have my NSS style surf blades made from 1/2". I think it'd be fine for a ghetto gate too.
1/2 is fine for strength. I like 3/4 for the ability to counter sink the screws and still gave some depth for the threads.
Fly little birdy!
Clearly that was a screen scrape from GoPro footage... Where's dat?!
On the laptop. I pull a screen shot via the app on my phone.
I'll get to work....
I wasn't referring to actual
work....
Pics of it together, hoping to try it next weekend. Russ, thanks for the idea!
Sanded the edges and glued down rubber weather stripping to protect boat.
http://i258.photobucket.com/albums/h...pstgyf54ak.jpg
http://i258.photobucket.com/albums/h...psebjtrsr2.jpg
http://i258.photobucket.com/albums/h...psggpys9zn.jpg
Built a quick one last night. Heading to the lake to test it out.
How long are you making those? And does adding more length make the pocket even longer?
Mine is 24 inches. Simply because the HDPE sheet was 24 inches.
I have not experimented with differing lengths so I can't say for sure. I can tell you that The pocket is plenty long with my setup. http://tapatalk.imageshack.com/v2/14...f5f64068a9.jpghttp://tapatalk.imageshack.com/v2/14...969274b2ac.jpghttp://tapatalk.imageshack.com/v2/14...11021f4beb.jpg
Mine is 24" long also because the board I had was 24".
I have very little time to experiment when at the lake. I left my ballast the same as before with the boat listing, and added the gate. I did have 3 kids sit on the side w the gate.
Pocket was much longer. There was a significant increase in push. I'm a beginner at wake surfing. The sweet spot was much more forgiving. Could go ropeless much quicker and there was way more area to work with.
mine is 20" along the bottom edge
Any details how you guys are attaching to non-custom, non-surf platforms? Besides the tied down straps to the transom.
