Has Fresh Air Exhaust (FAE) changed your wake?
Quote:
Originally Posted by
parrothd
Don't think it'll stall it or anything bad per se, just might restrict the exhaust giving a little less performance. Also when you pull the baot out that water would be trapped. Add some holes so it can drain.
Mine has a weep hole drilled in by FAE, right next to the flange where it bolts through the hull.
how did u make that metal/pvc adapter to your exhaust ?
5:00
Oh damn that should do it! If it comes off now, physics were some how broken.
Question for "Trayson"
