Removing the canvas is not that hard. Just don't remove all the little strings and balls if you don't have it. That's key. It takes maybe 10 minutes to put back on
Sent from my iPhone
Sent from my iPhone
Thanks for all the replies guys!!! One of my bearings are going out, getting that fixed this afternoon. Then I'll try laying down towels over the seats and dropping the Z5 then strap it down.
Haven't decided on the snap on cover yet, may pack it in the boat just in case we run into rain between here and Bethy Creek.
Checked my spare.... WTF!!! Somebody hijacked my spare and left me with a 5lug wheel! Trailer has 6 lug wheel...
*looooong sighhhhh 😡I would've been pissed if I left here not knowing that and ended up having a flat
Someone stole your spare? And you just noticed? And replaced it with a 5 lug?
Yea they either swapped it out while parked at the ramp or somebody from the factory put the wrong spare on the boat from the dealership...
I've spent all day trying to locate a 15" rim with a 6 lug pattern, not your typical set up! Finally found one, just need to make sure it will fit and then have to buy a matching tire
When do you plan on rolling out and heading this direction?
Sent from my iPhone
You shouldn't hit any Houston traffic at that tome
Sent from my iPhone
I use a cable kryptonite type lock on my spare. Way too easy of a "crime of opportunity" for someone to take it. In less than 5 minutes, some shady sob could hit a boat ramp and have a new set of tires/rims for their trailer.
Didja buy the boat used? The seller may have just slapped whatever he had lying around on there.
I bought my '05 this year and had two blowouts last time I towed (2 hrs.) Who carries two spares? Not this guy.
I now have all new Marathons by Goodyear on the trailer. I sure rest easier towing now.
I just returned from a 1,500 mile round trip adventure. Beforehand I redid the bearings and with fresh oil and seals. Had extras for each hub, all five tires are within one year of manufacture date. The only issue I had was the Oil in one hub turned white after a couple times in the water. I had all the stuff with me to fix it. Had no issues and pulled average speed on the interstate was 78. Early preparation is best.
Would someone please post a picture of the shrink wrapping they're talking about doing? I am interested in doing that but I'm not exactly sure what your shrink wrapping or how you're doing it.
I don't have any pictures, but used stuff like this left over from moving.
http://www.homedepot.com/p/Pratt-Ret...80SX/203609742
Basically, just tightly wrapped the tower speakers three to four times around. Kept everything tight and then it just cuts off. Also wrapped my Bimini cover as well. Bugs are a pain to get off and this made the five minutes worth it.
Dont forget the obvious. make sure you have a good big jack to actually lift the trailer. Too many people just grab a small wrench and little old jack just to be "prepared" but if they had to actually use it, it either wouldnt work out or would be WAY more difficult and time consuming than if you took the time to get the right stuff.
Oh and have a pair of gloves too so you dont have nasty hands after the job is done.
