Stainless exhaust fittings would be niiiiiiice.
i used gator grip for my gunwale pads. i replaced the swim deck with it, then used left overs. the pad goes from the tower to the back, in 3 pieces. had several comments from supra guys and others at marina about them
Heres where I got my Stainless through hull fittings. Good quality stuff!
http://cgi.ebay.com/ebaymotors/Set-3...ssoriesQ5fGear
As far as the rail goes I think they are around $150 but I don't remeber specifically. you would have to ask your dealer.
Newty, thanks for the heads-up on the ebay auction for the stainless thru hull fittings. Best price by far, especially since it's for 3 of them!!
I should do that integrated bow sack mod like you did (with additional empty pump), then I'll only have 1 extra fitting left after buying two sets of these!
I'd like any ideas on something for in between the cabin speakers. Supras have a nice billet badge there, as do a lot of other boats. It just looks a little plain... suggestions?
Bjames, I'm not sure. I know its a supra part prolly 08 and older, but all the skiers choice platforms are the same so it should fit on any newer platform. As far as mounting is was simple.
squeeg333 the sack works really well. I did have to put a spring check on the discharge of the floor sack to build enough back pressure to fill the ibs. Once the two sacs are filled it overflows out of the ibs discharge. The factory discharge pump has enough juice to push water through the check to empty the bag.
If you have any questions on how I did it let me know.
Newty, are the thru hull fittings 3/4"? My boat is in storage a long ways away, but I am wanting to order myself some SS thru hull fittings. Let me know when you can!
Yep they're 3/4. Super easy upgrade.
