shop that sells wetsounds here told me the same thing. they preferred to have the sub facing the floor, usually under a seat. I dont' have the room for that, but am still looking for a better location.
Mine are:
Wire Aux switch on dash to GIII ballast switches so Aux switch acts as a main power switch (done)
Iphone interface (done)
Install JL Audio M6600 6 channel amp
Seal subwoofer enclosure (foot box)
4 outlet heater
Dripless shaft seal
Wakeboard prop
Relocate v-drive warning light someplace that I can actually see it
We'll see how much of it actually gets done :)
Al, here's how you place it on top of the footrest facing the hull. You get much better sound dispersion this way.
Razz,
I'm confused. It that a subwoofer box and which way is the sub facing? Is it sitting on top of the footbox? Can you post a zoomed out view? What are the dimensions of the box?
Thanks,
Al
Al, yes it's on top of the foot box. What your seeing is the side of the box which faces rearward toward the drivers seat. The sub is facing to the right/starboard where the wire bundle is. I don't have a better pic other that these. If i remember correctly it's a 12.5x12.5x12.5 box, 3/4" thick for an internal dimension of.77 cubic feet.
Yes, please. Thanks.
