From an electrical standpoint, you will need to wire in the new power harness for the 770 and then run a new 2-chnl to the in-boat speaker amp and change the input mode on the amp.
Physically, then 70 is more rectangle and wider and the 770 is more square and narrower. So some fabrication is likely required.
