If still under warranty, submit a claim. They replaced mine, had a small pin hole and a fitting that had ripped out slightly
Follow up to this. Do not waste your money on the $12 patch kit from Fat Sac. I didn’t even fill the bag and it has started to peel. Going to pull it off and try Flex Tape.
Thanks. I will give it a try! I guess I should have known. They are in the business of selling Fatsacs. Not repair kits….
The Gorilla waterproof seal tape is really good stuff too.
I used 3M 5200 to seal up a small leak in the bond between the bag and the apron(?) material around the quick connect fitting. I slathered as much as I could inside and outside the leak/joint and (knock on wood) it has held for a season so far.
