Yeah even on the hose I think mine holds 167 or 171 even if revved up a bit.
Ran it on the 3/4" hose today and removed all the timers and gardening stuff my wife has on this output.
Boat ran 35 minutes and only got to 210 then held. Thermostat opened at 160 as designed. The output hose from the thermostat housing never got hot enough to burn me but the hose was rock hard so flow and coolant were not an issue.
The fake a lake plunger I have is not the greatest but water was running through the raw system pretty good. No coolant any where and the reservoir stayed full.
We will see what happens at the dock tomorrow. Anyone know how to clear the SPN code? Or does this one require a dealer?
I know this is an old post, but I was going to replace my belt as normal maintenance. Are you able to explain a little more in depth as to how you removed the raw water pump? Is it just the 3 bolts and it will pull out? Or is there more to it than that?
Yep. 3 bolts, hub on pump pulls back just enough to run the flat belt through. Bolt pump back to balancer.
The bolts completely suck to remove. Mine had factory orange thread locker and the paint helping hold them.
Put a white towel under the engine where you are working. This way it catches them if you drop anything. By luck I had one down to protect my knees and it saved me hours with a magnet.
How do you loosen the belt tension? I saw online you put a 1/2” drive socket into the tensioner, but it doesn’t seem to move easily like the video I watched. Do I need to remove or losses the hex head bolts to allow it to swing?
I also think I will replace that idler wheel. Do you happen to have a part #? https://uploads.tapatalk-cdn.com/202...80be50f879.jpg
https://uploads.tapatalk-cdn.com/202...932c92f621.jpg
It had a little wobble, so I was going to replace it while I have the belt off.
The half inch drive goes in the square hole on the right. My ratchet did not give me enough leverage. I used a 24" breaker bar and it was easy.
