Was One of the first checks
I would still throw a treatment in the tank that has a water emulsifier in it. It will help get any moisture out if this is your problem. A high volume station is least likely to have debris or moisture in the underground storage.
A loose fuel pump relay could be a thing also.
Ahhhhhh...this could be the culprit! I did have a bahama moma hat hanging from it at first. I think I took it off after that, and never hung it back on for the trip. It sat on the dash board. This is why I like this fricken forum! Everyone or someone out there has run into the same issue at some point in time. I thikn that might be it.!!! I am going to check it out tomm. Thanks
Sorry for all the reply's! Just got home from work and thought I would check in. Thank you all.....I am going to the lake tomm and am going to look into all of it. 65 gallons of Eth Free and 31 gallons prem for my truck. Will be a nice cheap day on the lake. Thanks again!
D
