My Supra starts with autowake on too.
I would love to know how to change this.
I noticed your depth gauge is showing zero as well in all videos. Not sure if that has anything to do with why autowake is on when you start up, but may indicate something being up with the ecm?
I noticed the wakeplate was at 100% in your last video.
Did this "magically" get fixed? Or if you engage cruise it goes back to 50%.
My friend craz doesn't start in autowake. I thought somewhere you could turn off profiles or surf mode and autowake won't auto start.
Leaning towards ECM issues of a bad sensor. Does the new boats still use a triducer? Hfarr mentioned 0 depth jist curious.
Depth always says zero because i didn't addon the depth finder in the build. My lake is 70 feet deep and didn't need it. Went out today and 4 times i started the boat to make videos for the dealer and the wakeplate did not work and then magically 1 time it did. I can't seem to reproduce why it works every now and then. The boat has not worked with cruise control since yesterday morning with multiple restarts and battery resets.
Check your battery ground cables. Either loose at the batteries, loose at the buss bars under the dash, loose at the amp rack.
I sound like a broken record on some of these post but ground issues will cause all kinds of crazy things. You have a ground cable on the motor also. A loose connection would explain all of these issues (except autowake running at startup)
I am having this exact issue with my 21 Mojo. I can even be up to speed and then turn on cruise, which kills the power down to 1,500 rpms. Like you I received the error message a couple times and now nothing, just stuck at 1,500 rpms when cruise is on. This happens with surfing, wakeboard, and Go Home leveling, any time cruise is turned on.
So far I've tried cycling the battery, trying each battery separate, but havent tried both batteries at the same time.
Someone on Facebook mentioned that I may be able to get into the Settings on the computer and do a hard reset, pushing everything back to factory default. When doing that, you'll have to reset your inclinometer afterwards. This will be the next thing I try when I get back out on the boat.
I also poked around to see if all cables and buses were snug. I suppose I should dig around and look a bit closer to make sure.
Yeah dealer hasn't got back to me yet and ive checked all the cables per previous recommendation and didn't find anything loose.
The opposite. I only have paddle wheel. No zero off. It's a 2021.
