Could you not calibrate you boat with weight in you boat as long as it's sitting flat on the water?
Sent from my SM-G998W using Tapatalk
Instructions for calibration of both sensors is in the display manual. The draft sensor will be very impacted by weight. The inclinometer zero calibration is the reference point for pitch and roll and is intended to be the boat sitting “flat.” I think it would be really hard to know if your boat was flat I’d you had a lot of gear/ballast/lead/people on board.
I was not impressed at 1st as well on my 22. There is a post on here that has pitch and roll setting for ext surf side. Great info. I have a small crew. My wife and 3 kids. 10 6 and 3. I run all ballast full and have 300 led in nose. I do not use auto wake. I use switches to fill bags and make sure they are full. Starboard surf inside 13.5 pitch and 7.5 roll and port surf I use 9.5 pitch and -3.5 roll. 11mph. I don’t really touch wake plate much at all. Wave is nice and clean and can surf it close up and far back for days. More people I get the bigger and even better the wave is. I plane to get more led but just haven’t yet but I’m happy now and it’s better than my 12 mojo. In the beginning like you my 12 was better but now the 22 takes it. It just takes time to play around with it.
If I want disable autofill what should my trigger and trigger margin be set at
2019 mojo with new software
Should trigger be set really high(myguess)?
Attachment 30483
Picture of the setting page
What version of the software are you using? Did you need to use the dealer code to get to the development screen? I don't remember that screen being available, (I may have missed it).
My software version: MoombaBP_MY22_47740_20211206
