Yes, do it. I am not familiar with the wake makers kit but I'm guessing they include 3 ballast puppy reversible pumps. Mount the pumps in a place where they are easy to get to. You will likely need to change the impeller every 2-3 years in each pump. Electric is very different vs the stock pumps. The new pumps are high amp draw self priming pumps so you will need relays. You want three under water holes (one for each pump) in the bottom of the boat. They will fill and empty through the same hole. The pumps will not allow water past them when you are driving so you don't need sprinkler valves like your current aerator pumps. You will also want an overflow hole out the side of the boat for each bag. You may even want two per bag. These burp the air out of the bags and allow overflow so the bags don't burst. It is a pretty straight forward job. Make sure you have a manual valve at each under water hole just in case of emergency. The new boats all include this. Be careful drilling through the fiberglass so you don't crack it. Not difficult at all. Watch a video or two and you will learn everything you need to know. The job is not difficult for someone with your skills. You will have no problem and you will be MUCH happier with the boat. IF you don't have one, get a "suck gate" for the boat too. It will massively improve your surf wave with the new ballast.
