Hey [mention]Tommy2slow [/mention] would you mind posting pics of the motor hose connection and placement of the blower. Thanks in advance
Hi Emilware,
My engine has blue labels with “To Heater “ & “From Heater” at the hose connections. Hard to see in the pic as I couldn’t find an angle that both were visible. The blower and hot tubes have a plastic cover that does a nice job separating them from the under seat storage. Tried to get pics of the hose routing under the hot tubes but they aren’t great. Pic of the wiring shows the yellow wire on my motor is not used. Hope this helps.https://uploads.tapatalk-cdn.com/202...cb4229386f.jpg
https://uploads.tapatalk-cdn.com/202...eb9ed4ac6d.jpg
https://uploads.tapatalk-cdn.com/202...bcbb4521ab.jpg
https://uploads.tapatalk-cdn.com/202...4e192ac8f6.jpg
Thank you [mention]Tommy2slow [/mention] this is perfect.
https://uploads.tapatalk-cdn.com/202...6aab33db9b.jpg
https://uploads.tapatalk-cdn.com/202...6a74d0a447.jpg
So I was able to complete the install of the heater Kit 200 pro which I bought for bakes online.com.
The entire install took about 4 hours. It uses the factory switches for the high and low fan.
Check out the installation video.
https://youtu.be/tJutNJfvfQI
Looks great. Glad the installation went well. That’s a great spot to install the motor and hot tubes. I didn’t realize you had a 2021 as the thread title was 2020 but all is good. We live in the north so our heater is essential. My son is training for the Canadian Wakeboard Nationals next weekend. 59 degrees in the water and 38 degrees in the air today . I will be pulling the boat out of the lake for the season as soon as we get back from the tournament .
Are you not installing a shower pump for flow through the heater?
My understanding is the raptors do not produce enough pressure in the coolant system to circulate coolant to the heater core. My pump went out and I had to bypass it for the time being.
Not getting super warm air out of mine at the moment although the blower still works fine.
Either way…nice install. Super clean!
https://uploads.tapatalk-cdn.com/202...15869e08ae.jpg
Heater in full effect after today’s session!https://uploads.tapatalk-cdn.com/202...fe3f775485.jpg
I had all the intentions for putting one in. As a matter of fact I ordered it from SC but still don’t have a ETA so I decided to try without. So far I have tested it and seems to do well. The engine temp seems to hold good and there is enough heat coming from it.
I do have a electric water pump for VW Jetta that will arrive Monday just as a back up. It’s $50 comparing to $205 from SC or $160 from heater craft.
If I need to install it will a quick job. My plan is to put it in the engine compartment.
I’ll do a video on it too.
