Has this just started after winter lay up and summerization?
1 check all clamps and strainer gasket seal to ensure you are not sucking air.
2 check the tranny cooler
3 remove the thermostat and distribution housing and look for corrosion. Remove tstat and test it in water on the stove.
if all are good then the seal on the impeller pump could be going.
