I am very sorry to hear that.
I found a line lock kit that would work on most trucks.
I'll admit that my boat sticks to our dry bunks really well and our ramps aren't ridiculously steep, so I unhook the bow chain and strap before I back the trailer down the ramp. So the driver never has to get out of the truck. And with the boat not attached to the trailer, the boat couldn't add to the mass of the trailer pulling the truck backwards, the boat would just float off the trailer.
But yeah, I guess it's a good idea to use 4WD regardless... We have plenty of times where the wife will nose me up to the dock, and I'll get the truck and trailer and then she'll nose up again so I can drive the boat onto the trailer (if it's crowded, or windy, or bad river current I won't have her drive it on--and we're STILL faster at loading than almost everyone else at the launch). So yeah, my truck is unattended with the empty trailer in the water for about 30 - 60 seconds. And that's all it would take. I do however reach over the bow on my XLV and can clip the bow hook myself after putting the boat on the trailer. so if someone else is backing the truck, they never have to get out. If I ever got a Max, I'm sure that wouldn't be possible anymore. But on the XLV, it's great to drive the boat on, clip the bow hook, turn off the engine, and have the driver pull us out while everyone else is chasing their tail.
You commented that the rear differential was in the water and you expected more differential fluid changes. The differential is a sealed unit except where it needs to have the 'breather'. Very often there's a breather hose (or you can add one). And it's a quite simple job to extend the rear differential breather line higher so that water can't enter. They even make one way valves for the end of that line to keep water out. It's a very common practice on 4x4 wheelin' rigs that see stream crossings as part of their usage. I had extended breather lines on my transmission, both differentials, and even a intake snorkel on my jeep.
got it.
we're talking about a stock silverado diff here. water has a way to get into anything. I bet there's some water intrusion just the dozen times or so we've launched the boat. my old ford had water in it and caused a $800 rear diff seals/service.
I follow your basic launch/retrieval process. driver of the truck never gets out. we never used 4x4 on ramps in idaho/wisconsin but here in nevada we have every time but I think it's more about the craptastic factory tires chevy sticks on their z71 packages. I think new rubber will eliminate the need for 4x4.
guess it's a good thing I need tires this winter......
I guess that's what I'm saying. Stock vehicles either don't have differential breather tubes or they're not very tall. So all that's necessary is to extend the breather tube up higher than the water level will ever get. Sometimes you have to be creative. But once that's done, the water won't get in the differential. It's a lot easier to spend some time and a few dollars in hose than have to mess with that stinky gear old in the diff.
That also was where I was able to convince my buddy that having a lifted truck for launching a boat is actually a benefit. keeping the drivertrain and body out of the water is a good thing!
I can throw the hook onto the max from the trailer so the wife's feet stay nice and dry..... not super comfortable but doable.
