Take an O-ring off, go to your local hardware store and match it up. I had some leaking issues and was going to replace O-rings but a little silicone lube took care of it.
I use a dab of white lithium grease on mine but silicone or Vaseline works too.
Well I had enough of the leaks and went full throttle in sealing the fittings. I tried new o-rings on the bags with silicone grease and it still leaked. So I put a dab or bathroom silicone caulk on all the fittings, manifold to bags, pumps to port outs. I’ll probably regret that later this season when removing the bags but Im over the wet carpet. She goes out for a water test to tomorrow....
