You will want to add as much as you can to the rear side you are surfing. Then move it elsewhere when you are not. If you only have 250 lbs or so, I would move it up to the bow and store under the seats when the bags are empty. That would be the best spot for slalom skiing. In my case, that is also best for wakeboarding, because with Autowake it is always draining Some of the front ballast and I have to move people up there anyway.
2018 Moomba Craz
