What did you do to that poor impeller? Sucking up sand and rocks?
Did you find the pieces?
If so, when you look in the engine compartment you will see the ballast hoses from the floor shutoff valves routed to that transom wall.
The manual says every 100 hours (same as the engine impeller). Autowake does run the pumps more than a normal system, but i was skeptical. I bought a set (6 for my boat), pulled the first one out and couldn't tell the difference between it and the new one, so I put the new ones on the shelf for another year.
