We are having the exact same problem with our 2017 Moomba. Did you figure out what the problem was?
Make sure your paddlewheel is properly aligned. It has arrows on it that should be pointing forward towards the bow. Can loosen nut inside the boat to rotate the assembly. It should be under your transmission hatch somewhere.
