How did you pump in the bowl sac?
Bow*[emoji848]
I made a manifold to go on the front of the floor ski locker ballast bag and used a hole saw on a drill to drill holes in the floor inside the bow storage area under the corner of starboard and port seat.
https://uploads.tapatalk-cdn.com/201...b7cb69a936.jpg
https://uploads.tapatalk-cdn.com/201...91b823e54f.jpg
It’s this one if I recall correctly
https://www.wakemakers.com/fly-high-...d-bow-sac.html
It won’t fill all the way without popping the cushions up but I’d say it’s good for 400 lbs
I could have sworn I replied to this thread already but apparently it was another thread asking a very similar question... Here's the copy-paste:
I came off the vent port of my floor bag and into the starboard rear fill/drain port of my Sumo 750. It does not drain 100% all the time, but only leaves a gallon or two - really only a pain if you're wanting to remove the bag. That hole was extremely hard to drill... not so much for the physical drilling but the mental prep...
I leave a length of hose coiled (I call it a service loop) to allow the bag to stay flexible and not put a strain on the fittings.
Nice thing is you start filling the floor bag and stop when the cushions start to bulge. About the same amount of time it takes both of my 750 rears to fill. Draining works the same way.
Here's the bag I have:
https://www.wakemakers.com/straight-...-750-2016.html
It does pop the cusions but I would estimate way more than 400lbs worth. My floor 400 plus 750 IBS fill time wise just shy of my 2 rear 750's, all off the same manifold - so I would say I'm getting at least 600lbs, maybe more. The best part of that bag is the long legs.
https://i.imgur.com/cIQ1ld4l.jpg
https://i.imgur.com/UmAYJXhl.jpg
https://i.imgur.com/v381wJQl.jpg
