Originally Posted by
Chaos
Circling back to the bimini sleeves, etc. What Chris says is correct, the black denier of a bimini can bake a board. It hot climates it can bake a board so hot that it melts the foam. Delamination is often something different. You can get a delamination from melted foam, but it is more often caused by outgassing or really foam with too much air in it. Not all EPS is the same. There is good EPS and bad. As a safe guard in the past we use to always put in vents that allowed the board to equalize to an extent. Modern EPS made for surfboard manufacturing does not require this. I haven't had a board delaminate in years. That does not mean you cannot make it happen.
The best place to put them in my opinion is get some straps or a rack that go on top of the bimini, with some simple pads and use a board bag. The Board bag becomes your sleeve. You hook, strap or secure the board bag, then just shove the board in when not using it. A good board bag will keep your board looking new for years. A wet board sock also works in normal bimini sleeves to keep the board cool.
Nick
