Should be at the very back of the engine compartment , zip tied to one of the black hoses
It should be between the engine and transom down low. Usually a white round housing attached to a 3" black flexible hose leading to a vent. Something like this.
https://newcontent.westmarine.com/co...rge/594002.jpg
Man thank you! I'll look again this weekend when we go back to the lake. Thanks for all the help.
Also, I'm looking to buy an engine repair/parts manual so I can learn everything possible about it. Can someone point me to that and/or recommend literature that will help me? I'm good with truck engines but not boat. But, this being a GM block and basically a truck engine, I'm mostly familiar, but don't want to miss anything.
Thanks,
Finally checked this. The blower fan was hard to turn by hand. It loosened some as I turned but still had a lot of resistance. Can I take it out, WD40 or grease it, or is it time to replace?? If so, where is a good place to purchase this?
And does anyone know the size blower? I found them on Amazon.
3"or 4" for a 2012 Moomba Mojo 2.5 Indmar Assault 333.
I would save the headache and just replace , should be a 3" , but I can't say that for 100%, the spare for my 17 is a 3" , but it was leftover from the last boat
Thank you! I would pull the old one but I'm 2 hours away! Ill guess and hope for the best!!
Ya , my boat is still at the dealer , so I can't look at mine , not sure if they would be the same or not being different years, i would go with 3" , good luck
When in doubt, open all your rear hatches for a bit and leave them open while cranking.
Looks like the Nautique steering thruster.
