You need to understand the SC / Indmar side of things.
To truly know if everything is aligned and working correctly you need to run the boat. Hince the 20Hr service. This allows them to make sure the engine, trans, V drive and shaft are all in alignment. This way your not causing damage by having mis aligned parts.
No different then the alignment on your car or truck. If its out the car still goes down the road just fine. Its just wearing the tires out much faster then needed.
If you bought a new car and it wouldn't go straight you would take it in for service.
If your drive train is out of alignment you wouldn't know just driving the boat. This is why a Dealer needs to look at it
You need to get the alignments checked, also if there is something wrong with the internals they can see this in the fluids when they drain them, maybe your cam is wearing wrong, or a bearing is going out, they need to check all these things before saying yes we will warranty you for 5 years.
Just suck it up as boat ownership.
After the 20hr you can do all your maintenance and save your money.
