Help with '15 Mojo surf settings
Quote:
Originally Posted by
Ironcross25
I have a 12 and surf regular. I run 1100 in port locker, 325 under port bench. 400 front full and off side 200. Running 10.5. Able to go ropeless while not for super long but each time gets longer. I Am still a beginner. Biggest push is closer to boat but I'm fine tuning wake plate to go farther back. I am able to surf farther back with ok push but if I care to hard I sometimes can't recover. I'm going to test a hair more weight on off side to see if that makes a difference and speed. I know the 15 is a diff hull I think but hope this helps.
You need more nose weight. If you don't have an IBS , add one. Also run a 300-400 lb sack in the bow on top on surf side. This will give you a deep pocket
