Originally Posted by
mnpracing
I enjoy pristine water while surfing. Can it be done in less that ideal conditions....sure. But so can wakeboarding, skiing, tubing, etc. Everyone wants clean water (except maybe tubers, or foilers).
I don't mind sharing with other boaters, but I do have an opinion on how to best share the calm water. If drivers follow a set pattern (straight lines, drop your rider, turn around without powerturning, and go back down the same line) it minimizes the number of waves to contend with.
My point is, we all could have had the best water possible (given the scenario of 3 boats running at the same time), by running parallel to each other. That way, we'd only have to hit each other's wave once per run, and the wakeboarder would have to hit the least amount of waves (due to speed as you note above). Perpendicular (or semi-perpendicular) can work too depending on the shape of the lake. We tried to adjust a couple of times, but no way to maximize the clean water when the others are driving circles.
