The fill and drain hose are the same, the hose at the top of the bags are vent hoses.
suggestions: set your timer about 30 seconds longer than it needs to be when filling for the rears. you should have a good steady stream of water out the vent port on the side of the boat. the bag then should be 100% full. add a one way valve to your vent line (from wakemakers) then when it empties it will run a little longer than needed. doing this and my rear bags are about 99% empty, just a few drops left in them.
now that hard tank in the bow is another story. never gets empty unless we park on the ramp and usually have to hit the empty 2-3 times more for it to finally stop emptying water out
