Originally Posted by
chadjitsu1
I have heard that if you replace that pump with a reversible pump you will get better flow. You might want to talk to wakemakers on that though. I hear that even though you have less GPM on the Johnson / Jabsco the head pressure is much better and will push through the sprinkler heads better. Even though the existing pump is high flow there is no pressure and the flow is minimal once it gets to the bags. Just what I have heard.
If you replace it with a Johnson your part way there if you decide to go with the elaborate system many of us have decided to invest in.
