Brian,
Yes, long before the stereo starts to cut out the audio performance really begins to suffer due to low voltage. The best solution for any towboat is to start with highly efficient amplifiers, like fullrange Class D for example.
A Class AB amplifier will consume 2000 supply watts to produce 1000 watts of audio output. 1000 watts is wasted in heat generation.
A Class D amplifier will consume 1250 supply watts to produce 1000 watts of audio output. 250 watts is wasted in heat generation.
The Class AB converts 400 percent more supply to wasted heat at the same output level than a Class D.
Problem solved and no need for an upgrade alternator. Plus, when you lift the observers seat it won't feel like a blast furnace coming out of the port locker in July and August.
Earmark Marine
