Originally Posted by
matt75
Boats in the shop and I didn't take any install pics. The horns require the most cutting of the roswell setup. The back of the horns are small, and then fan out. There are several 'strips' on the horn that interfere with the larger mounting surface of the roswell pods. When I first got them, the horn sat about 1/2 inch above flush in the pod if I remember correctly.
I would suggest the method MLA used as a dremel wasn't fun. it's pretty thick aluminum and be careful of the weld points on the mount surface.
My supra is a 2007 and you can see the 6500.2 in my avitar/pics section. The wires hanging down in the pic are for the 'soon to be installed' 55w light to led conversion I bought from roswell.
