Originally Posted by
EarmarkMarine
Al,
I know I get a little technical sometimes but I try to introduce the readers to different concepts rather than the same old same old, plus I want to provide the real reasons why.
The affects can be variable. If the charge level between the batteries are minimal than there is less voltage differential that is trying to equalize. As the charge level is quite a bit different due to a larger system, larger battery reserves and longer playtime at rest, the difference can be more profound and the risk can be greater.
If its not too much trouble I would recommend making the change.
Earmark Marine
