Thanks guys - When it is running it is definitely running smooth and i was surprised that it cranked so easily after sitting up all winter. I get the same issue when I push the button on the throttle and open it up. It still only revs to about 2000 RPM's or so. The other interesting thing is that it appears to only start to push the RPM's up when the throttle is open to between 9 and 10 o'clock. From it's start position around 12 oclock down to about 10 oclock it basically does nothing. (which is different from when I took it out of the water last summer).
The reason I fogged the Carb was I assumed I needed to based on the Winterization steps found in this link: https://forum.moomba.com/showthread.php?t=9877
But I guess that was for a EFI engine?? Not sure - this is my first year with the boat and still trying to find some of the basics (like where the freakin' fuel filter is on this thing :) ). Manual says it is under the Vdrive cover, but not mine :).
One other thing I noticed was that the Oil pressure did bounce between 40-60. Any thoughts on what may cause the new impellor to leak. That thing is a pain in the butt to pull so i want to make sure it is right the next time. I coated it with Vaseline before i put it in. Could the gasket just be on the wrong way?
Thanks again guys!!
