Originally Posted by
2007 Outback V
1.The vent for the bags, can I tee all three together and run one hose, that way I only have to put one hole in the hull for venting?
I agree with NCSUmoomba, don't do it for the following reasons: It will cost more, You really want to know when each bag is full.
Don't use a scupper intake with reversible pumps, it is not needed and will slow draining if the boat is moving. Use mushroom type intake(s). Wakemakers site says that a 1 in. mushroom intake can supply up to 2,200 GPH of water, and the Johnson pumps are rated at up to 720 GPH per pump, so 2,160 GPH for all three.
Have you decided where you are going to be placing the pumps?
[/COLOR]
