Remember that your strut bearing is water lubricated. So if you are attempting to turn your prop after being out of the water for a while, you will most likely have resistance.
Typically a bent shaft or mis-alignment will cause a vibration while the shaft is turning. This vibration will also increase as the mph/rpm increase.
