I will time each individual bag today and post the results.
Here are the results for the individual ballst bag fill times. The results are puzzling...
Left 6:56
Center: 6:50*
Right 6:20
What size sacs do you have DG
I agree. The build quality is much higher and now I don't need to worry about the valves anymore.
I had to take apart a couple Orbit valves a few times because the ballast bags would fill with water while underway.
It's nice to see the fill times decrease with the new valves when more water is flowing through them. That means they are an improvement when I upgrade the fill pump. I am really leaning towards upgrading to the Rule 3800 because no holes would need to be drilled to make it happen.
This tells you that the Irritrols flow better than the Orbits at higher pressures but not at lower ones.
You should really talk to the guys at wakemakers. Your stock 3/4" intake can only support so many GPH's so upgrading to the 3800 alone will not get you the results you are looking for. You will need to upsize everything in the flow path - intake, manifold, valves, hoses, fittings - to see significant improvements.
I upgraded mine to 1" and added two T-800's and it resulted in dramatic improvements and I didn't have to drill any new holes.
Here's a link to my ballast system upgrade including before and after fill times.
https://forum.moomba.com/showthread.php?t=11243
Al
JesseC has already posted his fill times with the following results:
Rule 2000 - 3/4" Irritrol 700 valves, 3/4" scoop, Time: 10.75
Rule 3800 - 1" Irritorl 700 valves, 1" scoop - Time: 9.33
I am shocked how the 3800 and upgraded intake and valves made such a small difference. Upgrading my Rule 2000 to a Rule 3800 is now out the window.
