Nice work!
Nice work!
He is pretty good he skis behind a 1986 supra ts comp "old school ski boat"
The hose i used and the 90's ( from Lowes) on the drain pump were quite a battle, so i had to use my boot lube to get them half way onand then clamp . i tried the needle nose trick but to no avail. If they pop of i will boil some water to stretch them. eveything from flow right fit perfectly even the threaded bag quick connects. let us know how it goes..
Brain, thats for all your support and stuff:p you were my inspiration. just got to pick up a 5 port manifold and an extra fill pump for the bow sac and i will be golden:rolleyes:
jmvotto, Where did you get the plate for the drain pumps?
Jester got them from the dealer.
part # 105046 bracket straight ballast pump $3.56
page 2 of this thread
https://forum.moomba.com/showthread....ght=parts+list
Thank you for the info. I will have to try and get them or make my own.
Where did you get the GII Switch panel? I want to put one in my boat this winter and can't find a place to pick this panel up. Shoot me a email if anyone knows where i can get this. [email protected]
got it from my dealer, i also had one from an ebay auction a three switch bertha ballast pre-05 version. you can also get single switches at wakemakers.com
http://www.wakemakers.com/wakeboard-ballast-parts
hope this helps
Where does your power come from for your power/fuse block? Is it dedicated wires directly to the battery?
Jesse, I powered the ballast fuse panel that came with the wiring harness to the bus bar connections under the dash.
