Brain,
sorry to hear about the trailer issue. that can just be fustrating enjoy your vacation, none the less.
Brain,
My 02 Outback LS trailer did this same thing. I called the dealer and he said to remove the wheel and bring it in. It did fine on the road until the hub dropped and was about to hit the road. I tied it up with a rope and off I went. They went ahead and replaced all 4 since they were afraid it was a bad run of torsion axels. I could not have been more pleased with the service. Fortunately I was only out of commision for about 3 days. It just happens, buy a boat, expect some repairs and issues.
Quick update... Jerry at Boatmate was great, as expected. He said it would be approximately 1 week to get the axle through paint and shipped out and that's exactly what happened. He got my email Monday and it was at my door the following Tuesday. Great service IMO!
But now I have to install this thing, ugh... I guess I didn't realize that it was the entire axle tube that needed to be replaced. Supporting the boat and trailer weight so that I can remove the axle will be no small task. My 2 auto jackstands aren't going to cut it.
I really hope someone does respond. It seems that BoatMate has had some bad press lately. I for one panicked and began closely examining my trailer (single axle, '04 LSV). I found that it had negative camber, oh my. After contacting BoatMate, I was informed that there is no recall, there were no "bad lots", the failures cover many years, and are relatively few in number. I also learned that negative camber is designed into the axles. Having grown up with a mechanic as a father, and working some for him while in school, I understand negative camber. I would suspect that they do this to make the trailer track straighter when being pulled.
I wonder if it's possible for you single axle owners to install a second axle, and swap out the fenders ??
Sure you could do it but it's a lot more than just adding an axle. You have to remove the existing one and relocate it so that the proper distribution of weight is maintained. You'd be better off IMO to just sell the single and buy a double.
I agree, you're definitely cutting & welding brackets in order to get the right weight distribution. It will come down to cost, like most things.
It would seem difficult to swap a custom painted trailer though, no?
I think it would be alot cheaper to add the axle, the parts are not very expensive and the welding shop won't cost that much IMO
I used to have a boatmate trailer....that damn trailer cost more in annual maintnance than my boat.
