Replying to Topic 'Trailer Help'
Very interesting. I was just at my dealer today, picking up my '03 Outback from getting some fresh oil. We are about to head off for a 7 hour drive with our boat, and I asked them about the tie downs for the rear. I have a safety strap for the front, but nothing on the back for 2 years. They said I don't need 'em because the boat is heavy enough that you don't need to worry about it.
I guess I'll be shopping for some tie-downs. Doesn't the belt rub the gel? I always envisioned protecting the straps with something.
Thanks!!!
Carsondoc,
What kind of straps do you use? I would like to get some that don't interfere with the swim platform. I have a 2004 Mobius LSV and the transom hooks on the boat are above the platform so I don't see where the straps could go to fasten to the trailer without somehow going over the swim platform. If you have pictures that would be great. Also, for everyone, for the front attachment, do you hook some kind of chain from the eyebolt in the front bottom of the boat (where the winch attaches) to the hook center and below the boat on the trailer? And, how long a chain would you need?? I currently don't attach anything except the winch to the boat - the dealer said it wasn't necessary. But, reading here, it sure sounds like I should. Thanks.
Shoemaker Mobius,
They are Epco 2" tie-down straps. Got them from my dealer with the boat. I'm sure you can find them on the internet.
When I tow my '99 Outback more than a couple of miles, I use two inexpensive ratching straps with hooks...these can be found at Wal-Mart, Home Depot, or any auto parts store...the trick is to also buy something to pad the ratchets to keep them from rubbing the hull...I got some foam pipe insulation, cut it down the center, and wrap the insulation around the ratchets...run the straps behind the swim platform, cross them, & you shouldn't have any problems.
Good Luck!
