I went with the 692 (now discontinued). I liked the fact that the aux in jack is in the back of the unit because I run a cable from the HU to the helm so it worked out better for me that way.
Volfo,
If you stick with Kenwood, the wiring harness should be the same so you just have to unplug the old and plug in the new. Plus if you have a Kenwood or Aeware remote, the Kenwood HU will be compatible with it.
Swapping out the speakers is easy. If you are lucky, the screw holes will match up. If not, you will have to redrill them but that's no big deal.
Al
