Originally Posted by
mmandley
3rd that with AWS.
I just got done with the 100 HR service from them. Its not a cheap service over 500 bucks, but they do a laundry list of stuff.
Some of it
Replace the spark plugs, cap, rotor assemble. 100 in parts right there.
Replace the engine oil, oil filter, trans oil, V drive oil, Fuel filter, and impeller, another 100 bucks in parts there.
Tune the engine electrically, check all electrical connections, check and adjust engine, trans and shaft alignments. Check and adjust shaft seal if applicable.
Full inspection of trailer, lights, wiring, brakes, hubs, lug nuts torqued, and if anything is wrong its fixed as warranty.
Lastly they send 2 guys to the water and drop the boat in for a water test, checking all the systems and everything on the boat.
For me AWS even replaced the drivers side tower foot pad that slipped out again no charge.
They also re-shimmed my front bunks as they weren't even touching my boat when the boat was on the trailer and this was causing my nose to slam into the roller when launching and loading the boat at any water depth. No charge.
Lastly they treated my boat as i would, they wiped it down after the water test, wiped the interior down so there was no spots, threw away there beer cans LOL.
I was told the tech spent more then 6 hours working and testing my boat and that alone is worth 500 bucks, get a car mechanic to spend that time on your car and see what it costs you in the end LOL.
Over all i was skeptical about paying for the 100hr service but in the end im really glad i did as now i have nothing to worry about this season with my boat.
Way to go AWS
