Originally Posted by
Brianinpdx
I have to admit, It's kind of nice from my point of view... having people out in the field with hands on experience with the enclosure. Because when the 50 questions come up, you guys have all the answers. and practical ones too!
Razz - if you have 22 gauge cable (or the like), Id run some beefier gauge and leave some slack as Cab found out.
Cab - I forgot to ask you on the phone yesterday, how the output was on the sub after you sorted out the wiring questions. You noted it blended well, but do you have decent output?
Mike - Not to be a stickler for details, but in the Exile line, Shift 12 has 2.0 VC, XPE has 2.5 VC, and all the big series have 3.0 VC's. what makes yours special is it has a heavier gauge flat wound high temp copper coil which will give it about 15-20% more power handling than a regular one. Seeing as the regular verison will take upwards of 2K watts, yours is got some extra wooof! And before anyone gets spooked about the hybrid design on the big 12, the paper cone part is sealed / sandwiched under the composite cone, to add rigidity while still being VERY light weight. This equates to very fast and accurate bass while still staying safe in a marine environment.
Cheers!
- Brian
Exile Audio
