I have both. Well, I've seen both. Some's got my Detention 2012 and I cannot remember who it is. Anyway, The Book has some more technical detail in certain areas.
I hear you. Both Detention 2012 and The Book leave out some detail on getting pop while jumping, and it's leaving me frustrated.Quote:
The problem is when i watch this sort of thing it leaves those critical parts out.
Unless you are amazingly double-jointed (meaning that your ankles aren't holding your board in a slight incline to bring you to the surface), the most likely cause for your issue is extending your legs. Have a friend watch or video you from the side. When teaching beginners who have trouble, I jump in the water with them and it's almost always a subconcious leg extension. They don't know that they are doing it, and will swear up and down that they aren't... but they are.Quote:
Like when you start in deep water, boat pulls tension on the line, you bring the board under the water and brings your heels of your feet to you butt. Then you ride up and out of the water.
That so doesn't work for me. I try and try that and all i do is get pulled over my board or drag out and lose my handle.
The Book has some animations that show exactly what should be happening above and below the waterline.
It is also possible that the driver is applying too much power. Tell him that the target speed is 15 MPH and you want a fairly light acceleration to that speed. After you are up, then signal him to go to your usual riding speed.
Before learning to come up in a slide, I spent years doing this, because it was the only instruction that I could find on the Internet when I started. If it works for you, great. However, it actually requires board control in three dimensions (tipping your leading toe toward the boat). So, I do not recommend trying to teach this to anyone else.Quote:
I ended up turning the board as the boat pulls me up and i come up out of the water almost in regular position.
Side slides are an excellent way to prepare you to ride switch and to land jumps. If you have any removeable fins, remove them and do some prolonged sliding exercises. This will teach you to use edging for control, rather than the crutch of steering with fins. You should eventually be able to turn around and do blindside slides in reverse (toeside).Quote:
The video wants you to come up in a side slide basically. This would be great if i can learn this as it will help me get to a switch position as well.
Sliding can be scarey (because of face-planting) to do at regular riding speeds. However, sliding exercises can be done at very low speed. I am 165 lbs and can slide at 11 MPH.
